Need rear shock help... QUICK?!
Old Feb 12, 2005 | 11:09 AM
Hyper Chick's Avatar
Default Need rear shock help... QUICK?!
Im in the middle of changing my rear shocks to the Bilstein HDs.... How tight do I tighten the top nut? TIA
Old Feb 12, 2005 | 11:27 AM
Cody Brooks's Avatar
the bilsteins have a hex shaped top on the rod at the top of the shock use a hex bit on it and a 17mm wrench on the self locking nut that bilstein provides just did the same swap about 10 minutes ago.
Old Feb 12, 2005 | 11:48 AM
Thanks, but that I know.... how tight do I tighten the nut? 1/2 way down, 1/4 way down, all the way down?
Old Feb 12, 2005 | 01:37 PM
DARK AGE 53's Avatar
Top nut 13 lb/ft, lower nut 66 lb/ft.
Old Feb 12, 2005 | 03:32 PM
mitchntx's Avatar
Originally Posted by DARK AGE 53
Top nut 13 lb/ft
Isn't that spec for the stock rubber bushings and not the poly bushings that Bilsteins come with?
The rule of thumb I've always used was until the bushing just begins to deform
Old Feb 12, 2005 | 07:21 PM
Country Boy's Avatar
Senior Member
I talked to thunder and they said all the way down untill the threads bottom out.
Senior Member
BTW~ That was me posting my my GFs computer
