Taking out welded subframes ??? Help please
Old Feb 14, 2005 | 06:36 PM
LS1[CHEVY]'s Avatar
Default Taking out welded subframes ??? Help please
I think the subframes I had installed are in wrong. The guy that put them in I found out did not have the car sitting right when he put them in. Looks like he reamed a few holes on the driver side . I think he reamed the subframe holes and my RCA on that side. Whats the best way to take them off and see the damage? Is this something a shop can easily fix? I was hoping I could get them out and maybe replace them with a bolt in set . Help !!!!!
Old Feb 14, 2005 | 07:31 PM
Flawless02SS's Avatar
i would say use a cutting torch or a plasma cutter
Old Feb 14, 2005 | 08:36 PM
2w0s060's Avatar
Prob gring the welds off, you could just grind the front welds lose put the weight on the car and re-weld, just a thought
Old Feb 15, 2005 | 03:54 AM
burnrubber's Avatar
yes, just use an angle grinder or cutting wheel to cut the welds and you'll be set. I can't say what a shop will charge guess it depends where you're located.
Old Feb 15, 2005 | 12:09 PM
LS1[CHEVY]'s Avatar
Thanks for the replies guys . I was hoping Rapidmotorsports would be able to do it. They are the closest shop to me . Anyone have any experience with them?
