Caster/Camber Plates
Tami
Tami
Get it to a shop as soon as possible and hopefully without it being far away.
Likely you are frying your tires. I would guess you have 3/4 inch total toe out with that big a drop. You have no need for camber/caster plates, you simply need an alignment. A lowered car can get over 2 deg negative with a lowered car and you can't run that much without killing the inside of the tires.
Align the car with 0.3 deg negative camber, max postive caster given the aforementioned and zero total toe.
That is a slightly more aggressive alignment than stock but won't hurt the tires.
Perry
Tami
Oh, BTW Perry has a good point; have the alignment shop set the camber slightly negative. If it gets set back to factory specs there is a good chance that your front tires will wear on the outside shoulder.
