Hal or Koni
I can't say they are better then a Koni because I have never ran Koni's, but I do like the QA1 set up. Hope that helps
I am going with Koni's because I daily drive my car, and they still offer adjustability which is nice. If I want a little weight transfer, I'd rather disconnect the front sway bar than drive around on drag shocks all the time. JMO
Exacly.
If you you car is pretty much a street/strip only car I can tell you that the HAL/QA1s are pretty nice and work really well. I like the "R" Series in the front with a fixed compresion, that way you can leave the rebound soft and the car won't bounce all over the place. Daily driving on drag shocks really isn't that bad if you adjust them for the street. You can reach the adjustment ***** with the car on the ground so it's a quick adjustment.
couldn't agree more or put it better myself. another vote for QA1's if you like the 1/4 mile.
Dave
http://www.frrax.com/rrforum/
The above site is for road racers and autoxr's, I learned a lot on that site, the ideal shock for superior cornering ability are Koni's, Koni's, Koni's. You can ask questions over there, you will be educated big time...
