Should I remove my traction control and how?
If you are sure you want to remove it, you can pull the under hood fuse and then remove the cables from the CC module in the lower right front and buy a cable for the non-TCS car. Unplugging the servo might cause a trouble code, though. LS1edit might be able to fix that if it happens.
