Car vibrates while braking...
Old Mar 18, 2005 | 10:52 PM
Darkspoon's Avatar
Default Car vibrates while braking...
..but only after i get on it. like on the highway, after gunnin it, when i hit the brakes the whole car vibrates..like a pulsation..any ideas?
Old Mar 19, 2005 | 12:06 AM
Deamon2002's Avatar
Well mine does this too. And no it is not normal. I had a Dakota and mine did this, well it got progressively worse, because the damage to my rotors was progressive. Wat you describe sounds like what I have in my Trans Am. Warped rotors, if you don't change them out or at lest get them turned and serviced, you'll be in deep poopy. After the pads eat away all the rotor material and get down to the inner vents/ ribbing, it sends to eat the pads to bits, and then your calipers. At this point it is not a serious problem if it isn't violent shaking, but just subtle, but it can be very damaging and very expensive. I recommend replacing the rotors for some more heavy duty ones. You can by simple replacements, but personally I would beef it up. You can get some Baer Eradispeeds, or Powerslots, both good brands. Or go really well and get C5 rotors from LGMotorsports, which I plan to get. It has performance C5 rotors, and a bracket that extends out your existing calipers to reach around the new larger C5 rotors. It uses the stock calipers and for a comfortable non squeeky ride you may still use stock pads. It all depends on how much money you want to spend.
Old Mar 19, 2005 | 02:14 AM
01_SuperSlow's Avatar
You have warped rotors, happened to me before.
Old Mar 19, 2005 | 11:42 AM
BrandonSS's Avatar
Another vote for new rotors... yours are warped.
Old Mar 19, 2005 | 08:01 PM
Fulton 1's Avatar
As noted above, you probably have warped rotors - its not uncommon. The correct/thorough way to check is to measure the lateral runout on your rotors while they're mounted on the vehicle. My guess (emphasis on GUESS), though, is that if you just replace the front rotors with some Brembo blanks (cough...cough... http://www.tirerack.com/brakes/resul...emium&x=83&y=8 ) you'll see the problem go away.
Old Mar 19, 2005 | 08:22 PM
Phoenix 5.7's Avatar
welcome to crally T/A rotors. mine are warped too. got Brembo blanks from tire rack to fix that.
Old Mar 19, 2005 | 11:55 PM
Darkspoon's Avatar
Will my warranty cover this? I have a bumper to bumper warranty until 90k miles! I guess ill find out on tuesday when I stop by my dealership. I hope they don't try to blame it on my rims or something.
Old Mar 20, 2005 | 12:54 AM
Your warranty "should" cover it.
Old Mar 20, 2005 | 07:44 AM
Gregg_98TA's Avatar
Warranty covered my warp rotors 3 or 4 times. Stock rotors are garbage and driving easy won't stop you from warping them. I ended up converting to Corvette brakes in the front to solve it.
Old Mar 20, 2005 | 10:42 AM
ddelallata's Avatar
get new rotors or have the ones that you have now turned/resurfaced. Get some new pads too or you'll just mess up the rotors again alot sooner.
Old Mar 20, 2005 | 12:21 PM
JParis's Avatar
rotors warped?
Old Mar 20, 2005 | 09:06 PM
Mud's Avatar
Mud
Wouldn't count on the warranty especially if you have exceeded factory warranty. Many aftermarket warranties will only cover drive train which usually means motor and trans. But hope yours will cover brakes.
Old Mar 21, 2005 | 10:46 AM
Kirby's Avatar
He did say bumper to bumper warranty and I agree with the others - warped rotors. Happened to me a few weeks ago. Mine were already old so I just bought new ones.
Old Mar 21, 2005 | 06:31 PM
Darkspoon's Avatar
I'm gonna take it to the dealer tomorrow, my only free time..car is getting worse now, it damn near vibrates everytime I brake! Yah I purchased a warranty that covers damn near everything which helps in this case..but sucks cuz I cant touch my motor, trans o nothing till like 90k miles!
Old Mar 22, 2005 | 06:28 AM
plopp's Avatar
it's the rotors. they are warped... My '99Z had new GM rotors installed when I bought it (the second set at 30K miles) ... it took only 6 months and they warped.... brake parts are considered 'normal wear' and are usually not covered by warranty...
I bought the $40 rotors at AutoZone and new pads - these are installed for 40K miles with no problems whatsoever.... it's not always only the most expensive solution that works best... good luck
Old Mar 22, 2005 | 10:35 AM
Kirby's Avatar
I did the same thing when I bought my car. It didn't take long before I started doing mods though. I think its against the law or something to have a bone stock f-body. Just do what I did. Keep the stock parts and if something breaks, put the stockers back on and then take it in.
Old Mar 22, 2005 | 02:18 PM
Darkspoon's Avatar
Argh well the dealership won't replace my rotors. A wear 'n tear item they say.
Old Mar 24, 2005 | 01:10 PM
plopp's Avatar
They would give you the same $hiddy rotors that you already have..... or skim cut the warped ones..... go to AutoZone, rotors and pads are $120 - 40000 miles on mine with no problems....
