cutting coils
If anyone is interested, I did a little write-up called "Stock Shock and Suspension Travel Specs" for the 4th gen F-body. It gives details on the shock travel vs. bumpstop under compression and so forth.
http://www.ls1.com/forums/showthread.php?t=496920
After you cut the coil, grind the bottom flat so that it rests flush on the perch.
I now have 1LE front springs, but will likely switch back to the cut stock springs.
Lower the rear easily by removing the upper spring bushing. Some people slide a 5/8 heater hose over the upper coil.
