Problem after removing calipers
Old Apr 1, 2005 | 05:20 PM
jargan04's Avatar
Originally Posted by evilbadz
OK I will just like to say that I am officially an idiot.
When I put he calipers back on, I put them on the wrong tires. I had the bleed nozzle facing DOWN which means all the air was in top of the calipers and not draining.
So yeah i'm out $70 because I put them on backwards.
Live and learn I guess
I was about to ask if the bleeder was on top or bottom. I know someone that did that.
Old Apr 1, 2005 | 09:04 PM
mitchntx's Avatar
Originally Posted by 0fbody0
Will channel locking the lines prevent you from having to bleed the brakes??? I am going to change my front rotors and pads this weekend and want to paint the calipers.
Andy
Would you crimp the fuel line closed to change a fuel filter?
reuse the 2 existing crush seals, buy yourself 2 1" 3/8" bolts and nuts. If it costs you $.50, I'd be surprised.
It might not completely seal the system, but it will slow down the hemorraghing to an acceptable rate. It should give you a couple hours to prep and paint your calipers.
Might I suggest you do the majority of the cleaning with them still on the car.
Or, go to O'Reilly's and you can buy fresh, clean reman calipers for $34 ...
Old Apr 2, 2005 | 10:24 AM
White.Lightning's Avatar
Thanks for the input mitchntx. Unfortunately it's raining up in the northeast. I will see if I can use a buddies garage or something to do the brake work.
Andy
Old Apr 2, 2005 | 03:22 PM
JasonWW's Avatar
Please don't break the lines just to paint them, they can be done on the car. If it is raining, the paint will not want to dry properly anyway due to the high humidity.
Old Apr 4, 2005 | 07:40 AM
Did the rotors/pads and an oil change last night. I am going to wait for a nice hot day to paint the calipers. It was extremely humid here. Thanks
Andy
