torque arm ???
Old Mar 28, 2005 | 05:52 PM
jimmy 2 Times's Avatar
Default torque arm ???
i am looking for a torque arm. What are the pro/cons of having it trans mounted, or crossmember??
also what brands do you recommend? have experiecne with?
thanks
Old Mar 28, 2005 | 10:15 PM
UMI Performance's Avatar
thanks
Mine will be released shortly
Ryan
Old Mar 28, 2005 | 10:19 PM
JMBLOWNWS6's Avatar
Ryan
When you make a adjustable one that mounts to the tunnel brace Im in. I allready emailed you about it Pm me
Old Mar 29, 2005 | 06:41 PM
sikws6's Avatar
bmr extreme here never had a problem! but if you are going for more of a street car I would use the adjustable full length maybe even with the torque arm relocation mount to take stress of the tailshaft of transmission my.02
M6HuggerSS's Avatar
depends on what kind of power you plan on putting down.
i decided on a trans mounted non-adj. BMR unit i got for $169 on sale!
and it works awsome for my set-up...
but if your ride is lowerd, you need an adj. one.
and if your up to 500rwhp, and non, tranny mount is better!
good luck.
Attached Thumbnails torque arm ???-smalltq.jpg   torque arm ???-smallrear.jpg   torque arm ???-smallrear1.jpg   torque arm ???-smallcut1.jpg
Old Mar 29, 2005 | 07:04 PM
JL ws-6's Avatar
Race your car!
I run a Spohn on my car, has good street manners, and works well at the track ( car hooked better than it did with the stock one anyway ). I run the one that mounts on a brace that replaces the factory g load brace. Ground clearance is a little less, but unless you are lowere, it souldnt' be a big deal. I never bottomed it out until I spaced it down to clear a huge 4 inch flowmaster collector
Personally, I'd reccommend a non tranny mounted arm, simply to remove the added wear and tear on the tranny and motor mounts. My .02
Old Mar 30, 2005 | 08:25 AM
Our first version will be a tunnel mounted adjustable set up. It will be released very shortly and I will put a post up regarding it.
Thanks for waiting for us, you won't be disappointed
Regards,
Ryan
Old Mar 30, 2005 | 08:33 AM
02WS6Bird's Avatar
Which is better for cornering Tranny mounted, Tunnel brace mounted, or Crossmemeber mounted?
Old Mar 30, 2005 | 11:46 AM
1CAMWNDR's Avatar
Did I see a post somewhere that there was a new tranny crossmember that had a box for a stock length torque arm? That would get it iff of the transmission, but would work with the dual exhaust I plan on getting.
Edit: tried search in Automatic Tranny forum with torque arm mount and got nothing related, tried again with crossmember and this popped up: http://www.converter.cc/drivetrain.htm
Tha is the one I was thinking of. Might need to get one of these with s stock length torque arm when the time comes instead of a chssis mount.
Old Mar 30, 2005 | 02:03 PM
sikws6's Avatar
BMR also offers one but it's adjustable seen it on another discussion hope this helps!
