i have a problem with my lca relocation brakets...need some help
hey i just picked up a moser 12bolt and it has lca relocation brakets on it already which is nice but there is a problem.
since the brakets bolt and then weld onto the outsie of the stock lca braket then now when i put the lca in the braket there is alot of slack moving side to side
it looks like the person just used a thick enough washer to shim the slack out but i wana makesure im doing it right befor i mess something up becasue i see like the spohn brakets put welded metal in there to take up the slack
thanks for the help
joe
thanks for the help
joe
Joe, I have the Spohn weld on's on my Moser 12 and it works just great
Also, the extra welded plate in there (taking up the slack) i would think makes them stiffer and stronger
Do you know what kind of relocation brackets they may be?
They may have made them themselves
Goodluck man
Goodluck man
i think they are the ones straight from moser
i looked at the bmr weld ins and they are made like the ones i ahve and they give you washers i think to take up the slack but im but sure
