Bump stops
Old Mar 30, 2005 | 08:43 AM
SSilverSSurfer's Avatar
Default Bump stops
is it ok to take the bumpstops off the my camaro. i have a feeling when i put my eibachs on its gonna constantly rub on there. i have 11's out back thats my concern. cause i hit a bumb and they rub. my buddy has 11's but his didnt rub, only when it would squat. he also has eibachs. any help...?
Old Mar 30, 2005 | 11:55 AM
felton316's Avatar
Its not recommended. Without the bumpstop, the only thing to stop the suspension travel is the shock internals. They can only take a good bump or so, then they break.
Old Mar 30, 2005 | 09:22 PM
Default reply
is there any way to assure my wheels wont rub if i lower it?
Old Mar 31, 2005 | 03:41 PM
Xsta Z 28's Avatar
Get wheels that fit correctly . . . .
But seriosly, removing the bumpstops is going to cause more problem than if they were there. The wheel/tire does not rub the bumpstop while driving . . . EVER! (unless you play Dukes of Hazzard) . . . .
The over sized tire combos can and typically rub on the inner, wheel well, and the wheel well lip.
The only time the bumpstops are a problem is IF you try to install the wheel and tire with the rear axle hanging in leiu of supported.
I cringe every time I see some one "recommend" cutting, removing the bumpstop . . .
Old Apr 2, 2005 | 04:41 PM
JasonWW's Avatar
Removing the bumpstops should make it rub more. Either I'm not following your logic or you are describing a different problem.
Can you elaborate?
