Koni SA on the way!
BUT, every time I tried to use any bump, I hated it and went back to full soft-right where SA's bump is set. Frankly, the only reason DA's came off (being in fine shape) was because people are very strange sometimes. They'd ask what I recommend, I'd tell them SA's. But sometimes folks wanted to look under my car, which is just fine. When they saw the bump adjuster they'd go nuts. Suddenly I lied to them and crap like that. I actually gave one guy a screwdriver and told him to see where they were set before going crazy. After that, he calmed down. So I switched just to eliminate the problem.
What I find most entertaining is that if I were going to lie, it'd make a lot more sense to tell everyone they NEED!!! DA's instead.....
DA's have their place, but it's very rare. And as good as the Koni Rebound adjuster is, the bump adjuster on the twin tube shocks (like these) isn't anwhere near as nice. They work, but use them if you need them and have a clue as to how to use them. I know how to use them, I don't need (or personally want) them. I have that set of DA's still, they are spares should I ever need them.
As for drag racing, in theory they should work pretty well. At the track, jack up the front. Adjust the front shock rebound to full soft (while counting the sweeps so you can put it back afterwards.) Then when you launch, it should allow the shock to extend easily to let the weight transfer to the rear. I haven't tried it as I'm not into drag racing, but in theory, it should work.
If you wanted to, you could also undo one of the front sway bar endlinks as well for even more weight transfer.
That's what I plan on doing once I'm ready for the track.
