Koni SA on the way!
Thanks!
http://www.ls1.com/forums/showthread.php?t=521349
That's what I originally meant.
Dailing them in for your actual car is a trial and error process. First get your tire pressures in order. Typically 31-33 in the front is normal for a 275, out back 25-29 or lower for a softer sidewall tire like the Nitto DR. Once you get that done I think you can move to the shocks.
Since we are talking about the SA we only have the rebound to look at. If I remember right, the rebound effects mostly the low speed circuit (whichs controls body motion) and only a little of the high speed circuit (which controls high speed bumps and dips). I would start with the rears all the way soft. Try turning them up and actually driving them. I found out pretty quick that all the way soft was the best setting for me. Anything more made the car too stiff feeling and offered no increase in performance. Now I am running 175lb rear springs, so if you are running lower rates you might like the way a little rebound feels in the rear, but you will probably prefer full soft, most folks do.
The front is a bit trickier. Too little rebound will make the car feel sluggish. Too much will make it skate (quick turn in to a corner won't allow the inside tire to drop quickly enough to maintain traction so it slides initially and then grabs). There is also a comfort limit. On my car the front can feel too stiff to the point that freeway driving made my stomach upset before the car got to the point that the front would skate. I like a quick turn in, but didn't want it to ride too stiffly as mine is a daily driver. I started out with 4 sweeps from full soft and added 2 sweeps after that. I test drove the car for a couple of days in between each adjustment. When I got about 7 or 8 from soft I could tell it was too much for daily driving so I backed it off 1 or 2 sweeps. Now it has as much rebound as I can stand for a daily driver. The ride is good and still has a quick turn in. I'm running 550lb front springs and a solid 35 bar, BTW.
I hope that helps some of you guys. Here are some more threads on the subject:
http://www.ls1.com/forums/showthread...hreadid=290931
http://www.ls1.com/forums/showthread...hreadid=272026
Rears - Set to full soft and then 1/2 turn back
Fronts - Set to full hard and then 4 sweeps back
Does this look decent to you guys?
I'd say somewhere in the middle of the front and somewhere near full soft in the rear is about right.
And a stupid question: What exactly is a "sweep"?
Thanks Jason
JasonWW what kind of springs are your running?
I'm running the GC fronts with 550lb springs, rear are custom made by me with 170lb linear rate with 35 solid/19 rear sway bars and Koni SA's all around. Here's my stance at 26" front and 26 1/4" in the rear:
More info here:
http://www.ls1.com/forums/showthread...=1#post5638157
I'll have to get my paper out of the car but my car with stock suspension sat around 28 on the driver side and 27 3/4 on the pass side. I'll get the pater and post it up tomorrow
There are pictures and everything. Just in case, turn the rears counter clockwise to get full soft.
Koni also has an online store if you need to order another ****. They are cheap.
