Suspension Problems!!!!
Old Mar 31, 2005 | 07:07 PM
kc7x7's Avatar
Question Suspension Problems!!!!
Hey guys, Brand new to the forum and need help with 01 TA NHRA suspension. Just too much motor, so im getting alot of wheel hop and body flex. Looked into sub frame connectors, But cant really find anything that will fit in with QTP cutout Y pipe. ANY suggestions???????
Old Apr 1, 2005 | 10:26 AM
jyeager's Avatar
I don't see why your cutout and Y-pipe would preclude sub-frame connectors...Unless you are talking about a set that has cross bracing that interferes.
You shouldn't have to go with that design in the first place. A set that doesn't use cross bracing should be fine. Check out the SLP SFCs.
SFCs will help the body flex and are highly recommended.
For the wheel hop you will want an aftermarket torque arm. Search the archives for product recommendations there.
The next step for traction would be lower control arms (LCAs) and LCA relocation brackets (these increase your antisquat which helps a lot in terms of traction).
