SLP Bolt In Subframe Install Question
Front drivers side.........as I recall.
If you dont see a clearance problem, bolt em up and torque em up
If you are concerned at all then just have the bolt heads spot welded. If you want to remove the sub frames in the future all you have to do is gind off the spot welds.
