ABS INOP what's wrong?
so, last night i checked both fuses under the hood. they both looked fine so i'm at a loss where the problem came from.
i've got a 12-bolt with abs hook up and it has worked for 100k miles in three different f-bodies. maybe the sending unit went bad? i havn't checked to make sure it is still plugged in yet. i'll do that tonight after work.
or, is there an abs relay i should try to replace?
please help!!! abs has saved me from a wreck more than once!!!
The usual suspects are:
ABS Relay
ABS Unit/Pump
Wheel sensor or speed sensor
Brake switch
The DTC code will most likely point directly to the troubled part.
one question though, my SES light isn't on, so will it still set a DTC for the other lights (service vehicle, abs inop, and brake light)?
