Weight of LCAs?
Nate
Stockers- 9.15lbs
Our Poly/Poly Mild Steel Set up- 8.75lbs
Our Single Adjust. Mild Steel Poly/Rod End Set up- 6.60lbs
Our Double Adjust. Chrome Moly Rod End/Rod End- 6.00lbs
Hope that helps
Ryan
As mentioned previously which we seem to concure with OEM stock weights being almost identical as UMI.
I wouldn't be concerned with the weight of these parts as they are all very close. If you prefer aluminum as mentioned in our previous discussion, BADZ has a very nice product. Most of the weight isn't in the rod itself, it is in the rod end components.
Measured on calibrated scale (lol on the bathroom scale comment...that must happen more often then not as I see numbers all over the place for any of our components)
Stock LCA : 4 lbs 8.5oz each.
Our LCA : 2lbs 11.5 oz each.
Rod ends are for RR and DR applications. Poly/rubber is good for DD. Don't go with rod ends for a DD car unless you have a higher tolorance for transferred noise and don't mind changing your rod ends more often.
Rod end noise also depends on the quality of the rod end, I have found less expensive rod ends to cause more noise. As Steve10 mentioned I don't think weight on this item is etremely critical seeing all items are very close, but that is your decision.
Ryan
