Eradispeed rotors/Hawk pads noise?
I just installed the baer eradispeed rotors and hawk hps pads on my car a couple days ago. I notice when i'm slowing using the breaks at about 40% and up, i can hear a sound, kind of like the sound your engine makes when you use it to slow you down. It's like a really low, quiet vrooom noise. Is this normal? I've never replaced rotors or pads before and don't know if either the rotors or pads usually make this noise. Thanks.
I was wondering the same thing about mine. I also put on Earl's brake lines at the same time as the rotors and pads a week or so ago.
Originally Posted by 2002 CETA conv.m6
Its bull.. This is my 3 rd set of baer rotors... Stock pads Baer Rotors = NO NOISE
Well, yours may be quiet, but many cars with slotted or drilled rotors do make noise. You can hear the brake pad "grab" the far side of the slot/hole as it spins back under the pad. This will make a growling or buzzing type noise/feeling. It's normal.
By the way, why are you on your third set of Baer rotors? And which rotors?
Thank you for that formal analysis of Hawk pads.
On the other hand, I've been happy with the performance of mine, even though they have that "buzzing" or "rumbling" sound under aggressive braking. Under normal driving conditions they're virtually silent.
