Is this Setup good cause its not working!!!! HELP
Did you do the swap yourself?
If it's coming from the front, a common problem is the top shock nut not tightened down enough. It leaves a gap between the hat and the top of the shock, and everytime you hit a bump, it makes a loud clunk in the front end, sounds like a wheel is going to fall off.
If it's coming from the rear, it could be like these guys said, bottoming out on the bump stops. Do a search on here for 'clunk' 'bang' 'thud' etc and you'll see a lot of threads about noises after lowering your car.
