witch LCA to go with
If you were looking for rodended LCA's, I would look at LG's steel ones. They use good QA1 rod ends and run $200.
If you were wanting poly ends, there are several to choose from.
http://www.lgmotorsports.com/shop/pr...5bca74f80ce7c6
He has a steel version with
poly/poly,
poly/rod and
rod/rod.
He also has an aluminum version in rod/rod.
You will probably have to call about the steel rod/rod as I don't see a pic on the website.
If you are sensitive to noise or vibration, a regular poly version might be better ( although they are not as good for cornering). I've heard they can fix wheel hop, but I have never had that problem.
Lowered cars also benefit from relocation brackets to get the LCA arms flat again.
Some say shocks can help with wheel hop while others say a torque arm can fix it. I can't really help with your wheel hop problem.
http://frrax.com/rrforum/index.php?act=ST&f=3&t=3553&
