heko with drag setup
You can start with the following
-Remove front sway bar
-Spohn rear drag bar
-LCA's
-LCA Relocation brackets
-Crossmember mounted adjustable torque arm
-QA1 Shocks and springs
-Poly trans. mount
If you wanted to go further you could also go with lightweight k member, front upper & lower control arms, solid motor mounts and weight reduction
BUT, the best thing you can do is get some seat-time...do the best with what you have now, it will only help you further down th road
