swaybar help
Old Apr 24, 2005 | 06:09 PM
Z-Nasty's Avatar
Default swaybar help
i was removing spring/shock when i disconect the swaybar endlink the long bolt that goes up from bottom the nut was rusted and trying to break loose i broke bolt i have a 98 camaro where to find this bolt? thanks for any help brian
Old Apr 24, 2005 | 07:07 PM
trackbird's Avatar
Almost any of the sponsors here can get you upgraded endlinks (that's called an "endlink" with poly bushings for better performance) or you can usually get stock replacment ones from autozone, advance, checker/shucks/cragan, napa, etc. Just tell them you need an end link (and front or rear) for your year and model car. Also, I'd replace them in pairs. Get 2 new ones and do them both.
Almost all of them break when you try to remove them. It's not unusual.
Old Apr 24, 2005 | 09:30 PM
dudemandanman's Avatar
yeah, i'm actually in the middle of lowering my car and the same damn thing happened. on both sides.
Old Apr 24, 2005 | 09:47 PM
absolut_speed's Avatar
I successfully removed mine... slowly, but the heat generated was amazing. Those suckers were HOT by time I got them apart.
Old Apr 25, 2005 | 04:54 PM
smokeum99ta's Avatar
A wire brush and some penitrating oil would take care of that problem next time. But if your cheap go to a hardware store and find a similar length bolt,nut and washer ,and thier you go. Just use your old stuff with it.
Old Apr 25, 2005 | 07:23 PM
Z-Nasty's Avatar
Thanks for the help guys,got two of them from autozone at 4.95 each. what are poly bushings? and how much better will they be? will i notice? my swaybar is still factory... thanks for any help brian
Old Apr 25, 2005 | 09:19 PM
If you plan on keeping the car for a fair amount of time, I'd order a new hollow 35mm bar from Stranoparts.com and get the bushing and new links that come with it. You'll appreciate the feel!
