ABS Delete Pics Needed
Old Apr 30, 2005 | 10:15 PM
Formulized94's Avatar
Default ABS Delete Pics Needed
COuld anyone that has deleted their abs, post pics of it.
Also for the people with tubular k-members, what did you guys do for brake lines?
Old Apr 30, 2005 | 11:21 PM
SJM Manufacturing Inc's Avatar
Here's picture of our ABS delete kits. They include a proportioning valve as well as a line lock with all accessories including the master arm switch, control switch and LED indicator. The kit including all fittings and parts necessary, no need to go out and purchase any additional fittings or adapters. Since the stock lines DO need to be cut and flared, we even option for the customer a 5.00 rental double flare-tool for use. The kit is complete ready to bolt in.
It enables you to completely remove your abs block and mounting bracket to relieve as much weight as possible in addition to cleaning up the engine bay.
The kits are for LS1 and LT1 vehicles.
If you already have a line lock either ours or SLP kits, the solenoids are interchangable. We sell the kits in multitude configurations.
Prices and options can be located at www.mycamaroz28.homestead.com
Steve
Old May 1, 2005 | 12:22 AM
Larry's Avatar
Here's my set up. Hurst solenoid with Jeg's proportioning valve.
http://www.mustangmods.com/data/440/...6image0001.jpg
