Cheap Lowering Mod?.....
Old May 5, 2005 | 10:07 AM
~JOSHUA's Avatar
Default Cheap Lowering Mod?.....
I have the 10 bolt out of the car right now. The rear springs are out right now. There is a rubber boot that goes on the top of the spring where it meets the body. Someone told me last night that I could take the rubber peice off and line the top of the spring with split hose of some sort. He said it would drop the rear about .75" till I do a real spring swap...
Has anyone else heard of this?
I don't like the fender gap the car has now. I WILL lower it but I'd like to chop the rear now for the short term. Does this sound realistic?
Old May 5, 2005 | 08:51 PM
69_YENKO's Avatar
yes, you can do that. it does drop the rear like 3/4" i havnt really heard to much about it good or bad. I do have a friend that cut his stock springs, he did half a coil off each spring and it made a world of differance with his finder gap. just dont use a torch to cut them, they will get to hot.
Old May 5, 2005 | 09:46 PM
Eugenio_SS's Avatar
it's known as the "hose-mod". use heater-hose on the 1st coil to avoid metal to metal contact.
The question is what you gonna do for the front ?
Old May 5, 2005 | 10:39 PM
psykoTA's Avatar
Nah man, the tugboat look looks cool ......
Old May 6, 2005 | 01:26 AM
SSpeedracer's Avatar
Dont cut the rear. Remove the plastic insulator and slide 5/8 hose over (if you want). Cut no more than 3/4 coil off the bottom of the front springs and grind the end flat (horizontal).
Old May 6, 2005 | 11:09 AM
~JOSHUA's Avatar
Thanks for the replies! The rear looks a BIT higher than the front, so I'm not worried about a "weird off angle look". I will do the hose mod in the rear to even things out and I'll keep y'all posted on how it goes. It looks too high in the rear anyway so I think this will be good.
