QA1/ HAL w/ stock springs
What exactly do I need to modify to have these shocks with front and rear springs. I am only looking for 1.7 60' times with a M6 on drag radials. Can these times happen without this suspension? My best right now is 2.2 on street tires. Money is an issue. Does anyone have a better idea?
Thanks alot for all the help.
In the rear you don't have to modify anything but you will have to buy some botls and washer for the lower shock mounts. For the front, you'll have to open up the inside of the factory spring perchs to sit on the QA1 perches. Or you can just buy a pair BMR spring seats for $50 that are made specificly for QA1s and stock style springs.
If you buy the QA1 front shocks you can pick up the QA1 front springs for about $40 each, or just buy a complete kit for around $689. QA1 isn't cheap but is also a very nice set up.
Hope this helps,
Ryan
Actually, the QA1s still don't come with the bolts/nuts/washers for the rear shocks. I helped a friend install these a couple weekends ago, and we still had to make a trip to the parts store for those things.
99 Pewter- I am glad to help when you are ready
Ryan
