POP! When braking hard.
Old May 10, 2005 | 09:24 PM
BrandonSS's Avatar
Default POP! When braking hard.
Any ideas on what to look for? Comes from the front.
Front suspension is BMR K, Blistein Shocks, Eibach Pro kit.
Its a pretty loud pop i've looked under it a little and nothing jumps out at me.
Any ideas?
TIA
Brandon
Old May 10, 2005 | 09:35 PM
BrandonSS's Avatar
After reading a few things... possibly the A-arm bolt(s)?
Old May 10, 2005 | 11:33 PM
Eugenio_SS's Avatar
do you feel it in the transmission as well. ?
I had TA mount get loose on the tranny side.
Old May 11, 2005 | 09:19 PM
BrandonSS's Avatar
Not really.. cant really feel it, maybe a hair in the steering wheel. The POP comes from the driver side front for sure.
Old May 12, 2005 | 10:02 PM
BrandonSS's Avatar
anyone?
Old May 13, 2005 | 12:08 AM
roy's Avatar
roy
Loose caliper bolt or bolts? If not i suggest going thruthe whole front of the car with a torque wrench.
Old May 13, 2005 | 10:29 AM
John_D.'s Avatar
I had a pop once in a while on a right-hand pull-out turn. (BMR k-member)
Ends up the k-member (to frame) bolts were torqued to about 35 ft lbs, I ran them on in to about 70 ft lbs and the popping stopped.
Old May 14, 2005 | 02:37 PM
cablebandit's Avatar
kmember-a/arm bolts...my BMR did that..i marked them with a paint pen when aligned so i could put it back if it ever came loose
