Do I need LCA reloc. bracs. w/ 275 Hal fronts & stock rear springs?
As the title asks, I've got a set of QA1s w/ 275 drag springs (gonna keep stock ride height out back) and Spohn poly/poly adj. LCAs waiting to go on my M6 car. Should I/Do I need the get the relocation brackets?
I had wheelhop issues after the M/T radials and the ram clutch,I installed CE rear shocks and LCA brackets with the LCA in the bottom hole.You can feel the car slam and hold the tires into the ground,a must do mod IMHO. Dissregard my 1.82,I pussed out last weekend and kept the launches under a hook and bog 3.5K to avoid riding on a wrecker like the previous week.
