Can Subframes be rewelded?
Old May 16, 2005 | 12:42 AM
H/C LS6Z's Avatar
Question Can Subframes be rewelded?
I've got a guy on ls1.com that has some used BMR subframe connectors that are currently on his car that he is trying to sell me. Can they be reused or is this a bad idea?
I've heard if they are just sanded down where they are welded they can be reused is this true?
Any knowledgable opinions on this matter would be much appreciated, thanks
Old May 16, 2005 | 02:04 AM
OldeSkool's Avatar
yeah, if the guy doing the grinding is skilled it'll be ok i guess... but... why not buy new? they're not majorly expensive parts... I think it would be far better to get some new ones
Old May 16, 2005 | 01:02 PM
jbuerke142's Avatar
I agree, they don't cost that much and I think it would be worth avoiding the risk to just buy new.
If you were going to go used I'd suggest seeing them before you pay.
Some people can probably remove them so cleanly you wouldn't be able to tell they were welded on. Some people.... can't.
Old May 16, 2005 | 03:25 PM
OldeSkool's Avatar
Oh, just a sided note. I hope this isnt a new trend... i dont think subframe connectors should ever be ground off... the sheet metal on these cars is like butter... i would be majorly ticked if i wound up with an f-bod that had subframe connectors ground off..
Old May 16, 2005 | 04:54 PM
Brett95z's Avatar
If its done properly, they shouldnt even grind on the subframe much at all. They are trying to take the weld out, not the subframe.
Old May 16, 2005 | 08:42 PM
jbuerke142's Avatar
Key phrase there being "if it's done properly"
Old May 17, 2005 | 01:40 AM
Pimpium57's Avatar
IMO, you should check out a pair of SFC's from UMI Performance (sponsor)--->
