Ground Control
Thanks
T
http://img.photobucket.com/albums/v3...A/4ea7fb32.jpg
http://img.photobucket.com/albums/v3...A/5a76fbce.jpg
Try a search for ground control here as well as on FRRAX.com. You'll find lots of pics. Including right here in this forum.
https://ls1tech.com/forums/suspension-brakes/320401-koni-sa-shocks-ground-control-coilovers-bear-gt-brakes-bmr-lca-reloc-brkts-pics.html
Here's a link to some pics of my install.
I'm very pleased with the set-up.
I have 650 up front and regular pigtail 175 in back.
fronts I adjusted about 1" drop. rear was about 2" drop without the upper spring isolater. so if its too much you can get about 1/2" back with the isolater.
backs were 175lb/in 11" springs. In my opinion 175 11" w/o spacer was perfect ride height. Althought the panhard bar was a bit lower than level, so if you dont' have adjustable pandhard rod mounts then you may want to keep the upper rubber. (LT1 car, rubbers are different)
The REARS can be had in 25lb increments.
I have the 500lb fronts & 150 rears as well, I love the ride of my car. If I'd do it over again I would probably have gone for the 550lb or 600lb fronts, just to make the front end a bit more stiff. The ride comfort and quality is OUTSTANDING, performance is VERY OUTSTANDING.
Fronts? Haven't messed with them yet, I wanted to talk to Sam & get his opinion for the settings on the front DA's with 500lb fronts...
