? on G2 springs
Originally Posted by BitViper
I got 2in....My car now sits at ~23 3/4 in (If I remember right) its a rougher ride than stock but with my other mods I corner like im on rails..If your looking fopr cush...you wont find it If you wanted soft..you shudda bought a cadillac ![Rolleyes](https://ls1tech.com/forums/images/smilies/LS1Tech/rolleyes.gif)
Maybe you could check your fender heights again. 23 3/4 sounds way too low. Ride height can have a big effect on ride quality, if your car is lower than other cars with the same front G2 springs, then your ride might be rougher as well.
I know it's been debated before, but maybe the Bilstein shocks (in stock valving) is having trouble controlling the high rates. I don't know, I'm just guessing. Like I said, I don't have the actual G2 springs.
PS, Bitviper, is the roughness in the front or the rear? I know the G2 is pretty low in the rear as well as pretty stiff. Maybe that's where your roughness is comming from?
