ABS light and drag wheels setup
Old Jun 3, 2005 | 01:38 PM
nick_s's Avatar
Default ABS light and drag wheels setup
Main question is can you run different tire heights front and rear w/o any abs troubles or lights? setup will be 26" frontrunners and 27.8" slicks out back.
Old Jun 4, 2005 | 12:52 AM
KGSloan's Avatar
no.
i've done this. it will throw your abs off and will disable it. however, it will turn right back on when you put tires of the same height on.
Old Jun 4, 2005 | 09:39 PM
nick_s's Avatar
sounds good - as long as it goes back to normal with my stock tires/wheels. thanks
