torque arm relocation kit?
Old Jul 5, 2005 | 07:17 PM
  #41
ssPetess's Avatar
Originally Posted by Hardtop00SS
did you have a spohn tunnel mounted TA?
no tranny mount
Old Aug 12, 2005 | 10:31 PM
  #42
JGA's Avatar
JGA
Hi
If you have a Spohn tranny mount torque arm and it interfears with your aftermarket Y pipe (and/or tunnel brace), you can turn the unit around and put the adjuster at the top. The bracket on the differential has to remain in the original orientation. Unbolt the arm from the differential bracket and just flip it around (adjuster to the top). It will give you lots of clearance and it works perfectly. I did it and it works great. The only disadvantage is that the adjuster is harder to reach on top. It's a simple solution and it works. I got my unit set to minus 1 degree and it hooks up nice. Big improvement in handling also. At least I am driving the car now and if I decide I want the relocation cross-member for BMR, I can add it later and flip the arm around then.
Thanks JA
Old Sep 8, 2005 | 09:10 AM
  #43
No Juice's Avatar
So what I am reading is that the BMR tranny crossmember hangs about 1"-2" lower than the stock. Is this right?
Old Sep 8, 2005 | 09:14 AM
  #44
ssPetess's Avatar
I believe it's more like 3/4" lower.
Old Sep 8, 2005 | 09:16 AM
  #45
No Juice's Avatar
Thanks Pete
How much noise do you hear with this setup? do you get a lot of clunks like a tunnel mounted TA?
Old Sep 8, 2005 | 09:23 AM
  #46
ssPetess's Avatar
Thanks Pete
No, no clunks at all. There is however a whining noise which is louder than before but I believe it's because of the poly tranny mount. Barely noticable with my GMMG
I didn't want the tunnel mount TA because of clunking and ground clearance issues so I went with the spohn tranny mount TA. Their TA does a great job but is a terrible design. The lower bracing goes way too far forward, more that necessary. It was hitting my Y so I had to then get the cross member relocation brace. I'm a bit worried that when I go with headers and a new Y, I may still not have enough clearance. If I had to order another TA, I'd go with Global West tranny mount, probably the best available IMO...
Old Sep 8, 2005 | 09:32 AM
  #47
No Juice's Avatar
So its almost as quiet as the stock setup except for some tranny whine?
I'm so tired of the driveline slack clunking with my tunnel mounted design
Old Sep 8, 2005 | 12:04 PM
  #48
WS6FirebirdTA00's Avatar
i have no more road noise than i did before. and yes mine hangs about 1-1.5 inches lower than stock. before the lowest point on the car was the ypipe and now it is the trans cross member. pissed me off becuase bmr didnt say this when i asked them they said there was barely a difference. but now its about 0.75 inches lower than the ypipe and before i had a lot more clearance from the trans brace
Old Sep 19, 2005 | 04:29 PM
  #49
sunsetta's Avatar
Good idea, mounting a thin rubber insulator between the relocation bracket and floor pan. I will be doing mine in the next week or two.Thanks again.
Old Sep 19, 2005 | 04:38 PM
  #50
sunsetta's Avatar
Check Stealth Performance for the lowest price if you want the BMR components.
Old Sep 19, 2005 | 07:50 PM
  #51
UMI Performance's Avatar
Hello Members,
Just wanted to let you know we are currently working our own design of transmission cross member with torque arm relocation. So far it is a nice unit and we are keeping ground clearnance issues at a minimum, shooting for no clearance to be lost, I will know more shortly as we get it installed and tested. So please keep us in mind.
Also there is no noise issues with our tunnel brace mounted torque arms.
Thanks for the time,
Ryan
Old Jun 24, 2006 | 03:42 PM
  #52
damon_Z's Avatar
When is the version for the automatic coming out? Thanks in advance for the info.
Old Jun 25, 2006 | 06:24 AM
  #53
99WS7's Avatar
sorry to hijack...
I just ordered the UMI adjustable tranny mount TA...was that not a good choice if plan on running atleast 500 to the ground on spray at the track. I dont want to put unwanted stress on the tranny. My car is low to and thats why I didnt get the tunnel brace set up.
Old Jun 25, 2006 | 04:55 PM
  #54
bad6as's Avatar
will this set up transmit sound?
Old Jun 25, 2006 | 04:56 PM
  #55
bad6as's Avatar
Originally Posted by UMI Performance
Hello Members,
Also there is no noise issues with our tunnel brace mounted torque arms. Thanks for the time,
Ryan
should have read more of the post, owned my self
Old Jun 25, 2006 | 11:26 PM
  #56
Marc '99T/A's Avatar
As opposed to waking the dead why not just call UMI or shoot Ryan a PM?
Old Jun 26, 2006 | 02:29 AM
  #57
revtime's Avatar
Thats a pic of my BMR tranny crossmember for a TH400.
They sent me a 6 speed one by accident and it hangs lower than the automatic crossmembers.
Just an FYI.
Old Jun 26, 2006 | 11:44 AM
  #58
PERFECT Z28's Avatar
I have personally cracked 2 tailshaft housings...thats why I bought my BMR TA reloc.
It does have an annoying vinration, but I haven't broken any tailshaft housings since.
Old Jun 26, 2006 | 09:41 PM
  #59
01ws6450hp's Avatar
I have dual 3" with an X pipe. Does anybody have a set up like this with the TA relocation mount? My exhaust runs right beside both sides of the tunnel.
