adjustable shocks. what kind?
They do not adjust height. Adjustable coil spring perches let you adjust ride height, which it sounds like is what you need.
Or you could remove the upper isolater pad on the higher side and replace it with some heater hose just to keep vibrations out. That will lower that rear corner about 3/4".
Maybe one of the isolators broke apart?
The worrysome part is if the front is off more that 3/8". Try fixing the rear and the front will be effected some as well. So that may fix it or at least get it close to level.
