Are the mounts for the C5 rear brakes the same for Fbody rears??????
Before you do that, read this:
http://www.stoptech.com/whitepapers/...erformance.htm
there might be a need, but knowing that the F-body's front end weight bias is only slightly changed by even a few weight saving modifications, you should watch to make sure that your vehicle actually needs a larger rear brake system before spending the money on them. By experience, not having a properly proportioned brake system is dangerous and possibly deadly.
