Spohn Torque Arm alignment problem...
Old Jun 15, 2005 | 11:05 AM
Slow Z28's Avatar
Default Spohn Torque Arm alignment problem...
Pieces: Spohn Tranny mount torque arm, Yank Torque arm relocation crossmember, 9" rear
Obviously i read the instructions and used the correct holes for the 9" rear.
i got the torque arm bolt in the rear hole of the rear end/torque arm. the problem is the front hole. it's not aligned correctly. it seems to be because the relocation crossmember pushes it off to the side too much and won't work. now i could unbolt the crossmember and then move it over so the other bolt fits in, then try and get a couple of friends to "stretch" the front of it over to align again, but isn't that putting too much stress on the torque arm from side to side?
would i be better off filing out the holes in the torque arm to rear end mount so that the bolts fit?
Chris
Old Jun 15, 2005 | 06:37 PM
sikws6's Avatar
when you put the torque arm on without the relocation crossmember does it line up with your stock torque arm transmission mount?maybe it's not the torque arm but the relocation crossmember?
Old Jun 15, 2005 | 09:37 PM
Slow Z28's Avatar
There's a TH350 in the car, so i couldn't/wouldn't be able to tell. it pretty much lines up right above the centerline of the trans, but COULD be theoretically "moved" over enough. but to get it to the tranny crossmember would put about an inch more strain laterally on it
