Panhard Rod Question
Old Jun 23, 2005 | 12:28 AM
DOUBT IT's Avatar
Default Panhard Rod Question
If you have a slightly bent panhard rod, is it okay to keep riding on it, or do I need to find a replacement?
I was switching my regular tires back on last Sat after a night at the track, and noticed this. It's slightly curved near the driver's side end. I was thinking of going back in with a takeoff stock piece, or a UMI non-adjustable. All I've done to lower the car is remove the spring isolators in the back ( 'cause the weight reduction I've done had the *** end up in the air ). I'm not planning on ever lowering the car any further, since I like to drag race a lot.
Should I worry about replacing it? And if I do, should it be with the stock piece, or with the UMI piece?
Oh, and I'm short on cash right now, so I really can't afford much of anything.
Any advice would be appreciated, thanks in advance,
Allen
Old Jun 23, 2005 | 01:15 PM
DOUBT IT's Avatar
Anybody?
Old Jun 23, 2005 | 05:15 PM
NoTicketsPlease's Avatar
SLP has a used panhard bar for 9.95$! This would be a cheap solution for you....who knows what shipping will be though. Here is the link
If you are ever going to lower your car you will need an adjustable panhard bar. UMI sells theirs for 100$
Old Jun 24, 2005 | 04:14 PM
00 Trans Ram's Avatar
Hell, go to a junk yard and grab one - it'll work on a budget.
Of course, the optimal solution would be to get a new one. Or, if you've already got an adjustable one, you could buy a threaded aluminum tube, nut that costs money, too.
Old Jun 24, 2005 | 04:19 PM
DOUBT IT's Avatar
What do you guys think about a 1LE swaybar? I just need something that won't bend. It looks beefier than stock.
Old Jun 24, 2005 | 05:08 PM
pimpmaro's Avatar
concerning swaybars, I'd definitely recommend one that bends. They're made out of spring steel for a reason.
Old Jun 24, 2005 | 05:13 PM
DOUBT IT's Avatar
Oops, I meant 1LE PANHARD ROD...
Old Jun 24, 2005 | 06:51 PM
pimpmaro's Avatar
Lol.
I'm not 100% sure about this one, but I don't think there's a 1LE panhard bar.
Old Jun 25, 2005 | 12:44 AM
DOUBT IT's Avatar
Lol.
http://www.slponline.com/view_product.asp?P=70401
Old Jun 25, 2005 | 12:52 AM
trackbird's Avatar
Lol.
There is. It has upgraded bushings in it. I'd buy the 9.95 from SLP and upgrade it later (if it's "that" bent). Any pics?
