Annoying creeking/squeeking noise
the only thing i've done suspension wise are SFCs, installed about 2-3 mos. ago. Creeking noise is heard when backing up and driving forward, on the passenger side rear wheel area. This doesn't happen everytime, but more often than not. I thought it may either be relating to the SFC on that side, but bolts are torqued properly, and I'm wondering if it's a shock issue.
Has anyone had this? If any, I'd like to know what it is.
Thanks.
Tony
Thanks.
Tony
Dude I am way ahead of you! I have more creaks coming form my rear thanyou can imagine. It is most likely caused by lack of grease. Go and try that....polyurethene *spell* doesn't like to be rubbed against metal. :yup:
I got the same annoying problem It's coming from the righ side Panhard rod bushings im going to take that and the LCA's off and grease them down properly with some heavy silicone grease. Everytime I grease them down now the sound goes away but then comes back a week later,I think the bolts are on way to tight, IT'S DRIVING ME CRAZY!!!
