Adjustable Panhard rod?
I lubed it up.. installed it.. centered it..
When I shift my car (m6) there is a LOUD HARD CLUNK like a trans mount is busted but it feels like the rear end making the noise.
It didnt happen before the install and happend IMMEDIATELY after the install.
Everything is tight.. do these panhard rods do this?
It SUCKS *****!
I am gonna swap out the panhard rod and go back to a stock one.
It is embarrassing when I tap the gas next to another car and all you hear is CLANK!
When you apply power the rear will want to rotate as well as move forward. The panhard bar is stressed very little to none at all under acceleration. So something doesn't sound right. If you can't see an obvoius cause, swap the stock one back in and see if the noise goes away. Panhard bars in general are pretty quiet, so I suspect something else is making the noise.
Someone else brought up that if the jam nuts arent tightent to the fullest extent they clank ALOT.
I will use Loc-tight on them and see if that works.
But first I will swap out the umi for the stocker and see what happens.
thank you for the feedback though.
Definately some really good advice
~Steve~
It shouldn't clank due the jam nuts under acceleration, but if they were loose and you rock the steering wheel left and right, it might.
Breaking a mount at the same time is unlikey, but you never know. It's worth a check.
It was my torque arm by the trans came unbolted OMG!
Was banging around HARD no bolt.
I fixed it today.. the umi panhard rod was FINE the whole time. I hope I didnt cause any grieve with UMI it is DEFINATELY A GREAT PRODUCT!
Regards,
Ryan
