Gotta a new panhard bar - whose is best?
Not to jack this thread but my PHR with rod ends makes alot of of noise not harsh noise but just alot of creaking(Sp) sounds on turns and bumps is this just one of the negative that come with a PHR like this.
Are you sure it's your PHR??? I've heard of them (and heard them) clunk from time to time... but I can't think of any reason why they'd creak... unless you might not have tightened them enough??? Or it's another part of your suspension... ?!
You can find out if you have the rear centered under the car by using a plumb bob off the fender and a tape measure to a known point on the wheel (please, do this on level ground otherwise it just doesn't tend to work as well). If you don't have the mounting bolts tight enough, I can see reason for it to squeek... possibly such if the jam nuts aren't quite tight enough either... I'd go back over the whole thing and make sure everything is tight.
