How can I reduce brake fade?
LS1TECH Sponsor
You are simply overheating your front pads. You not fading your fluid, though having junk in there is not smart and ATE is great bang for the buck.....
It's not your rotors, it's not your brake lines. You are simply asking too much of your stock front pads. Spend $60 on a set of PBR MetalMasters (which I use on my car), or HPS's or HP Plus, or any number of just better brake pads.
Note you do not need go crazy here. And I'm still baffled as to why Trackbird has such issues with HP Plus pads, because most folks love them.
__________________
LS1TECH Sponsor
Does the pedal go to the floor, or stay at normal height?
Autox takes not a lot of brakes, but when we use them they can get hot. My rotors are blue and get heat cracks in them too, but I never faded the stock pads. I submit something is wrong somewhere else.
__________________
I put a set of Ceramic pads on the front of my car and they are Garbage for stopping. You can get one good stop then they are done. They will be coming off the car here in the next few days.
What would be a good set of rotors to go with along with these pads mentioned above?
LS1TECH Sponsor
Note: Rotors are all iron, they all work. It's just a matter how good the quality of the rotor's metal is. And that's more a durability, warping thing than a stopping power item. The rotor is acted on by the pads. In that function a chinese POS will stop the car too.
We use Brembo OEM replacements. Excellent quality, and extremely durable in terms of resisting warping. Available front and rear both.
__________________
the rotors aren't the issue, the pads are, so I'm a little uncertain as to why you are wondering what rotors would "go along" with those pads.
Thanks for the response on this Sam. the only reason I was asking about rotors is because the car has 25,000 miles and the rotors have been turned once. I think it is time for some new ones.
I can't say that I've ever paid attention enough to decide if it's on the stops or not. I think I'm putting it on the floor, or nearly so (I'm just not sure which). Maybe I'll bleed them again. It does not seem reasonable that I'm seeing the amount of fade that I've been getting.....
