Koni shock with ground control spring
Old Jul 23, 2005 | 08:50 PM
YellowToy/A's Avatar
Default Koni shock with ground control spring
I just got some used koni shocks and was going to get some ground control coil over with a 400 lb/inch rate for the car. Why is this not more commen? Is there a problem with this. It is only 200.00 more that a XXXX lowering spring. Is this a bad idea?
Old Jul 23, 2005 | 09:16 PM
absolut_speed's Avatar
Not a bad idea at all so long as the used shocks aren't blown.
Old Jul 23, 2005 | 11:24 PM
felton316's Avatar
Its not a bad idea at all. There is alot of people running Koni's and GC. I'm currently running the setup but with a 600# spring.
Old Jul 24, 2005 | 02:54 AM
DONAIMIAN's Avatar
More people run that setup than what you would think. The ones that normally run it are the ones that dont post their mods in their sig. Do a search and im sure you could find out a lot about the set up, but most run with 500# springs or more up front and 150#ers in the back.
