Quietest torque arm options..
Old Jul 30, 2005 | 01:20 AM
OldeSkool's Avatar
Default Quietest torque arm options..
I'm wondering about welding a crossmember mounted torque arm to my subframe connectors. Would this be quieter than a torque arm mounted to a transmission crossmember?
Seems to me that it would be quieter since the load is spread out across the 4 subframe points as opposed to the trans crossmember which is right under the seats.
Old Jul 30, 2005 | 01:50 AM
Ferocity02's Avatar
The crossmember mounted one would be louder. The noise from the torque arm is going through one bushing. And then everything is solidly attached from there... crossmember to subframe connecters, to subframes. Noise from a tailshaft mounted torque arm goes through the poly bushing on the tranny, then through the tranny, through the soft tranny mount, then through the tranny mount crossmember into the car, or it can go all the way up through the motor mounts. There are many more noise deadening objects for a tranny mounted torque arm than a crossbrace mounted one.
Old Jul 30, 2005 | 01:54 AM
OldeSkool's Avatar
Right, i know tailshaft is the quietest... but I'm talking about relocation crossmember or weld on crossmember, which is louder?
Torque arm --> poly bushing --> torque arm relocation transmission crossmember
Or
Torque arm --> poly bushing --> crossmember --> subframe connectors.
Old Jul 30, 2005 | 01:59 PM
Ferocity02's Avatar
Oh... I misread that. I would imagine that the subframe mounted one would be quieter.
Old Jul 30, 2005 | 02:54 PM
OldeSkool's Avatar
thanks!
Old Sep 8, 2005 | 09:22 AM
No Juice's Avatar
I'm interested in this TA relocation tranny crossmember. So how do you guys like them? is it quieter than a spohn tunnel mount design?
Old Sep 8, 2005 | 11:36 AM
OldeSkool's Avatar
having no experience with tunnel mount setups, i'm unable to make a comparison. But the trans crossmember design is considerably noisier and clunkier than the tailshaft mount.
Old Sep 8, 2005 | 11:38 AM
No Juice's Avatar
thats not what I wanted to hear
Old Sep 8, 2005 | 02:05 PM
OldeSkool's Avatar
and its most definitely not what I wanted to pay $250 for.
