Suspension geometry question...
Mind you, I haven't analyzed the forces or moments associated with the design, so this is speculation, though I do have some background in design.
Makes sense BlackSS... I was just pondering bolting a bracket and rod end to the top of the 3rd member and affixing a beefy rod from it to the trans crossmember. One because I can't find a suitable traditional torque arm setup that does what I want. Also, it would free up space for a sweet true dual exhaust
The triangular shape of it is for strength in stopping these rotational forces and to attach at a single one-point mount in the front.
That being said... The best "simple" design of a torque arm is to use a mount like Spohn does on the rear end and to run 2 straight parallel tubes up to a similar mount near the transmission. When you accellerate, the rotational forces of the rear end are going to pull on the upper bar and push on the lower bar.
The problem lies in the ability to strengthen the front mount to take all the rotational forces without breaking. Spohn and others take this into consideration by attaching the two bars together to mount at a single point. The attachment of these two bars equalizes the pushing of one bar and pulling of the other and attaches them at a single front mount.
Also, LCAs are supposed to allow the rear end to move that way. This is why rubber is okay, rod ends are best, and poly is sub-standard for cornering. Suspension travel is GOOD, not bad.
If you have problems with one-side squat coming off the line, fix it correctly with a sway bar. The poor man's route is to use an air bag.
). The triangular shape of it is for strength in stopping these rotational forces and to attach at a single one-point mount in the front.
Ignore everything said here. The torque arm always sees twisting. Every time you go through a corner and experience body roll, or hit a bump with one side and not the other, the car sees one side go up and the other side stay the same or drop. The rubber mount is designed to allow this movement.
As I stated before, though, my whole line of reasoning was conjecture based on the geometry of the suspension and not actual numbers. I don't know how significant any lateral forces or moments are on the torque arm, though they do exist, especially if you're not going in a straight line. Thank you for your clarification though.
These are quick simple sketches, hope they make sense. But you should be able to see why axle rotation is solved in both cases. For simplicity lets say that there are rod ends at the end of each red line. This would prevent any push/pull and thus rotation and also would allow for pinion angle adjustment in either design. Also, about the second design, the location points on the chassis normally wouldn't be strong enough... but assume welded bmr subframe connectors to reinforce.
I guess what i'm saying is, I understand why the factory design is the way it is... All the parts are made out of sheetmetal and everything has rubber bushings which give and flex and wouldn't be suitable for either of these two alternative designs. I just see the factory design as the LCA's and torque arm "fighting" eachother (because of the differing radii) once the slop (rubber bushings) is taken away...
Im just trying to kick around ideas for alternative setups. I look at a solid rear axle and I know that all that needs to happen is for it to be able to move up and down in one plane (may be a mild arc) There are dozens of different ways to do this. 3-link, 4-link, 5-link, Z-link, etc.. I have no real intention of doing anything different to my car, just enjoying the tech discussion.
The TA can't be rigidly mounted on both ends (using the LCAs as a twist limter as you suggest) because that would result in a suspension that has 2 different lever lengths mounted rigidly...result is suspension bind. You wouldn't be able to articulate the rear suspension up and down.
What you want to do could be done if you mounted this new-fangled TA on the same bolt line as the LCAs (in effect adding a 3rd LCA to the system, but it would mount at the top of the diff case). This would remove any binding issue during suspension travel, but would result in wildly changing pinion angles as the axle articulated.
There's nothing extraneous in the OEM design. They'd love to save material, cost, and weight if they could.
The first setup you diagrammed OldeSkool, the axle would rotate counter-clockwise as the suspension compressed. In the second, the axle would rotate clockwise as the suspension compressed. I'm not sure how these would affect pinion angle or handling, but I am sure they both would affect both of those things in different ways. You don't have any rotation at steady state, but suspension motion induces rotation of the axle.
- This does result in a single upper control arm, but doesn't have to result in pinion angle changes, it just depends on where you fix the front of the new upper control arm. Consider the front suspension, you've got an upper and lower and by choosing the right length of the 2 arms and the right mounting location you can design a suspension travel that has minimal camber change...this is analogous to a ladder bar suspension, but with only one upper arm which would probably be a strength issue.
- I stand corrected @ there being suspension bind, I don't think that was right, but both ends of this new upper control arm (revised torque arm) has to be able to articulate.
