Sub frame connectors
Old Aug 1, 2005 | 01:20 AM
The PAT WS6's Avatar
Default Sub frame connectors
im looking into gettin some subframe connectors? i had a few ?s i was thinking of going with the bolt on ones how hard are they to install and what is the best sfc's out there? i would like some red ones. if anyone has pics that would be awesome
thanks
Old Aug 1, 2005 | 01:41 AM
ls12000's Avatar
Depending on what you want sub frames are for strengthing the cars chasis and eliminating interior rattling noise. If strenght is what you want then i suggest Boxed. If Clearance is you prefrence then go with tubed. Theres lots of companies that sell subs and they are probably all good I have Hotchskis boxed subs on my T/A and they are welded on, you cant even see them unless you get under the car. They eliminated lost of noise rattle to Id go with Hotchskis they are one of the best out there
Old Aug 1, 2005 | 01:46 AM
Full-Force's Avatar
Look at the ones made by UMI which is a sponsor. They have a nice staff too. I have been in contact with them lately.
They have boxed sub frame connectors for 139.99.
Old Aug 1, 2005 | 01:47 AM
BadBlackZ's Avatar
thanks
I was gonna ask the same question but i decided to search first and your posts was one that i came across, but after looking further and searching more, to me it seems they are all about the same. Everyone was saying all of their brand names of sfcs and all of them were happy with them. Im just gonna look at a few brands and kinda compare the prices i guess.. Im sure you can get some red ones but you may not be able to see them at all.
Old Aug 1, 2005 | 01:55 AM
ya i like the ones on umi but they are weld in is there any differecnce between bolt on or weld ? where exactly to they go, any one got sum pics
Old Aug 1, 2005 | 02:03 AM
BadBlackZ's Avatar
Im sure by welding them in would make it more rigid, but i read of some bolting of sfcs and they say they could weld them in also if they wanted. What do you mean by where do they go? Are you wanting to see if you can see them on the car? the sfcs connect the sub frames together, they run from front to back under the car on the sides almost under the driver/passenger seats. Sorry if that is not what you meant
Old Aug 1, 2005 | 02:10 AM
BadBlackZ's Avatar
Here is some helpful info, plus there is a pic on there a few posts down of a boxed sfc. Hope that helps
https://ls1tech.com/forums/showthrea...ame+connectors
Old Aug 1, 2005 | 08:08 AM
skywalkrNCSU's Avatar
SSU, come over and relax
you should get welded its not that much to put em in (i got mine done for $65) and that sucker is in there.
Old Aug 1, 2005 | 09:35 AM
LiquidFire350's Avatar
if i remember right, i think weld-on ones are cheaper than the bolt-on version
and if you want strength and clearance, i think Spohn makes tubular chrome-moly sfc
Old Aug 1, 2005 | 01:34 PM
Luna's Avatar
yea most of the weld on ones are MUCH cheaper , So between buying the welded and getting them welded you probably break even between welded and bolt on
Old Aug 1, 2005 | 03:00 PM
Reject's Avatar
i've been looking at this too, but heres my question when you are taking out the motor and you have to drop the front subframe and your welded, what happens?....
Old Aug 1, 2005 | 07:33 PM
The old man's Avatar
I have the UMI weld in.... V6 Bird installed them... He did a fantastic job and the car is much more solid now..
Old Aug 1, 2005 | 09:53 PM
get an engine hoist and pull it out the top
i think the the SFC welds onto the the subframe which is kinda part of the body, what you would have to remove to get the engine out is the K-member which is not welded to the SFCs
someone correct me if im wrong, ive never pulled the motor, or had SFCs put on, yet
Old Aug 1, 2005 | 09:58 PM
Reject's Avatar
hmmmm, need to read therw all my email subscriptions on the taking the motor our again, need to have a visual to get an idea.
Old Aug 2, 2005 | 03:49 AM
DONAIMIAN's Avatar
If I had to do it all over again, I just woulda got a cage and been done with it, lol.
Old Aug 2, 2005 | 12:26 PM
CAMJAG's Avatar
Im problly the only person on this forum with the Jegs ones. They are boxed bolt in cost me $170. I just put them on this weekend and it was kinda a bi*ch. I had to drill holes up front and the Y pipe was in the way and i had to un bolt that to get a right angled drill in thier (Hope u have one) and on the passanger side i had to unbolt the the pipe up at the exhaust manifold. On top of that were u have to drill in the side of the frame thier was another piece of metal thier and tightining the bolts was a another story and just put it this way i will never be able to unbolt them. All said and done they work awsome no rattles nothing hiting no noise just a much firmer ride. They only weigh 12.5 Lbs each too.
Old Aug 2, 2005 | 12:30 PM
Reject's Avatar
that means i'd have to loose 26 pounds to even it out again.....I dont think thats goin to happen... OOH OOOH taht or get more power to make up for it, now that i like!
Old Aug 2, 2005 | 02:51 PM
pimpmaro's Avatar
That's not a concern. The motor is bolted to the K-member, and the subframes are welded to the front unibody subframe. I have a writeup on dropping the engine out the bottom (thanks Cal!) if anyone's interested. Unfortunately no pics on that yet. Maybe once I get the new website up and running... I've been a slack *** lately.
