steering wheel shake
the car itself doesn't pull to the left or right,
it's only the steering wheel that seems to be bouncing/shaking left to right,
I had my wheels balanced and the car aligned and it's still doing it,
any help
thanks
pat
OR if it only happens when you are on the brakes, then you have warped rotors. Also how many miles are on your car? If its kinda high then the tie rod ends might be getting loose. I hope this helps.
new rotors, and the tires are brand new also, as far as the tie rod I'm not sure, car only has 37K miles,
pat
my car has the same problem, new balance alignment and everything, still not fixed. looks like i need new brakes. The Best V8 Stories One Small Block at Time
