Where to find Banjo Bolts for front calipers?
I am in need of the part number for the banjo bolts that connect the line to the caliper. I know that they're M10 x 1.0, but no parts store carries that size.
The stealership told me that they sell the bolt WITH the brake line for $45 each
. Hell no! Seriously, where could I pick up the banjo bolts only??
![MAD](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_mad.gif)
Fitting, RR Brk Hose Part of 1 (M10 x 1.0--6G Thd 8) 10286122.
This is the bolt for the 95-97 banjo brake line, rear. It is part of an assembly too, but maybe you can get one individually because this is the part number for the bolt only.
It's M10 x 1.0 like you want. In 1998 only the number for a bolt only was part 22163795.
There are some washer/gaskets involved too.
The front brake line for the 99-02 does not show a separate part number but rather comes as an assembly only as you found out.
Also http://www.nutsandbolts.com/bolts.html
Good luck.
Good luck.
