line lock abs bleed?????
Old Aug 10, 2005 | 07:31 PM
jlwade's Avatar
Default line lock abs bleed?????
anyone out there know how to bleed the abs unit after you put on a line lock???????
Old Aug 10, 2005 | 10:20 PM
Blacker's Avatar
Just bleed the brakes like normal. I installed my Line Lock 2 years ago and did not have to bleed the ABS Unit. I bled all four corners since it had the original brake fluid and need a good flushing.
Old Aug 13, 2005 | 09:51 PM
Flawless02SS's Avatar
yeah just bleed the calipers, I got away with just bleeding my front two. I used a Mighty Vac.
