Torque arm relocation bracket
Old Aug 12, 2005 | 04:08 PM
OldeSkool's Avatar
Default Torque arm relocation bracket
Ok. How about this one guys?
Old Aug 12, 2005 | 04:12 PM
MeentSS02's Avatar
Kleeborp the Moderator™
You would just need to do some extensive testing to make sure it didn't fail. If you don't care about your safety, give it a shot, but you'll be a guinea pig.
Old Aug 12, 2005 | 04:33 PM
OldeSkool's Avatar
WooHoo! Someone lemme borrow a metal brake and it'll be time to
Old Aug 12, 2005 | 08:45 PM
sikws6's Avatar
If you mount there it its still going to pull up on the transmission tail shaft
Old Aug 12, 2005 | 09:57 PM
OldeSkool's Avatar
Yeah, but if you think about it... it will pull up on trans tail shaft, only as much as the trans mount will let it... so it'll break the trans mount way before it'll break the tailshaft... i'd rather replace the mount than the tailshaft
Old Aug 12, 2005 | 10:21 PM
jimmyblue's Avatar
Moderator
It looks to me like the horizontal part that is
sandwiched, has no reinforcement to keep it
from flexing. Too cantilevered and thin, the
end of the TA will deflect under load.
I have a Yank relocating crossmember and the
mount is straight vertical, in the plane of the
TA arc and the crossmember bucks the load
with a stiff cross section.
Old Aug 12, 2005 | 11:35 PM
OldeSkool's Avatar
I guess i should have put in the "why" behind this. Basically i'm am completely dissatisfied with every torque arm option out there. The only thing that is smooth and quiet enough to satisfy me is a tailshaft mounted torque arm. BUT i don't want it to break. I'd rather break this bracket or a trans mount than the tailshaft housing. Not that i'm running enough power or traction to worry about breaking anything, more of a peace of mind thing "if by some chance i should happen to hook and gain 200 ft lbs of torque... at least i wont break the tailshaft." BTW... i've posted a few of these little imaginitive sketches of mine, none of them make it to reality, i think of them as mental exercises. Thanks for everyone's input!
Old Aug 13, 2005 | 06:33 PM
JGA's Avatar
JGA
jimmyblue
Hi does the Yank crossmember raise the front mount up higher. I need to create some clearance over my Y pipe so I can fit a Spohn torque arm. Raising the front poly bushing up an inch should give me enough clearance.
Thanks JA.
Old Aug 14, 2005 | 07:39 PM
CrawlinWS6's Avatar
Import Patrol
I don't think that this would be a great idea, just used the tried and tested relocaters.
Old Aug 14, 2005 | 08:37 PM
JGA's Avatar
JGA
Hi
Sorry, what are the tried and tested relocators?
Thanks JA
Old Aug 14, 2005 | 10:26 PM
OldeSkool's Avatar
he's talking about relocation crossmembers like Yank and BMR which i have tried and tested and personally dont like or the Spohn and UMI tunnel mount T/A's
