braking problem after CCW 505a install
Those that put on your ccw 505a's, have you had any braking problems? Right after I put mine on, I've had severe braking problems. At speeds over 55mph, even light braking is problem. For some reason the brake pedal gets hard and I get the feeling like traction control has kicked in, and then when I get to about 25mph the brake pedal becomes soft all of a sudden. Sometimes i get the low trac light as well. I'm thinkin my rotors might be warped but i'm not getting that vibration liek a warped rotor would give. My pads are good as I just replaced them. Every other car out there can out brake me and there is something seriously wrong. Can anyone provide some insight into this?
btw i have not tried putting my stock wheels back on to see if the wheel size was the problem because i have a flat in one of them.
