May be a dumb question
Old Aug 14, 2005 | 09:24 PM
Camaro477's Avatar
Default May be a dumb question
Im thinking about putting 1" drop springs on my car, if i do so, is there anything i'll have to get to go along with it, other suspension upgrades. THANKS
Old Aug 14, 2005 | 11:06 PM
pimpmaro's Avatar
well you'll probably also want to upgrade your shocks to match the higher spring rates of the new springs... and you'll also need an adjustable panhard rod (look for Trackbird... he makes a great one) to re-center the rear end.
Old Aug 15, 2005 | 10:07 AM
Camaro477's Avatar
thanks for the help
Old Aug 15, 2005 | 12:41 PM
DONAIMIAN's Avatar
Shocks can be expensive, so one option is to upgrade the front shocks when your lowering the car, thoes are the hardest to get to. Although I still recomend upgrading all 4.
Old Aug 15, 2005 | 03:46 PM
Camaro477's Avatar
Im mostly just going for the look.
Old Aug 15, 2005 | 05:18 PM
pimpmaro's Avatar
I can understand that, but you'll still want to upgrade the shocks. When you lower a car, you must increase the spring rate in order to keep the car from bottoming out continuously. The stock shocks can hardly handle the stock spring rates and increased spring rates will wind up with a dramatically underdampened car. Have you ever seen a ricer bouncing down the road like a basketball? That's because they installed lowering springs without adequate shocks.
Naturally you don't HAVE to get new shocks, but I guarantee that if you do get upgraded shocks to match your springs, the car will look better going down the road and will drive much better as well.
Old Aug 15, 2005 | 07:45 PM
Camaro477's Avatar
So what would be a good springs and shocks combo, with a 1" drop?
Old Aug 15, 2005 | 09:11 PM
pimpmaro's Avatar
Check out this link and see what looks good to you. Not a whole lot of options for a 1" drop.
http://www.angelfire.com/my/fastcar/suspension.html
Old Aug 15, 2005 | 09:57 PM
Camaro477's Avatar
what springs and shocks do you recommend?
Old Aug 15, 2005 | 10:09 PM
Camaro477's Avatar
the only reason i wanna just drop an inch is because my long tubes hang way down. I don't know much about suspension, but If I bought a set of Bilstein HD shocks and eibach 1" lowering springs, would that work and would the car just be dropped one inch. Help me out guys.
Old Aug 16, 2005 | 03:15 AM
DONAIMIAN's Avatar
I have the jet hot long tubes like you have and I run a pro kit. The headers are tucked up about as good as you can get. My y-pipe sux, but I plan on getting a new one made with oval tubing to gain some clearence so I can drop it a lil more.
Old Aug 16, 2005 | 07:55 AM
Camaro477's Avatar
So I could get a 1" drop spring and say the bilstein HDs and that would work for a nice 1" drop? THANKS
Old Aug 16, 2005 | 04:15 PM
pimpmaro's Avatar
For a 1" drop, maybe give the hotchkis springs a try. I have absolutely no experience with them but people seem to like them quite well and they shouldn't be too rough for a street car (looks only).
EDIT: Another option is to pony up for a set of Koni SA shocks and use the lower front perch and the heater hose mod for the rear to get the drop... and your handling would be much better.
Old Aug 18, 2005 | 03:38 AM
AW794's Avatar
He wants to know that shock to use with the 1" lowering springs.
Old Aug 18, 2005 | 04:10 PM
pimpmaro's Avatar
Whoops, I thought I mentioned that... Heh. It kinda depends what springs you decide on, some have higher rates than others. You can go with bilstein HD's, but revalves would probably be better. However, if you use the koni shocks, I can't remember how far exactly you can drop the car, but you can get great shocks and a drop without swapping springs.
